installing casters
  • Anna
    • 728
    • CA, USA.
    Anna,
    Can't help but confuse you more.
    These are from Rockler, and if you can match up the diameter and threads from your existing casters, they should work a charm.
    Funny. That was what I was looking for originally, but I thought there are no sleeves for these things. How does one figure out what the thread count is on screws? Is it just a matter of counting the number of threads per inch or is that a misnomer in the same way that a 1"x2" is really 0.75"x1.5"?
    Thanks for pointing this out. Just searching the rockler site for screw on t-nuts or teenuts don't even show this page when I tried. I had to type in the item number.
    • mpc
      • 1018
      • Cypress, CA, USA.
      • BT3000 orig 13amp model
      Anna -
      Machinists haven't "cheated" on dimensions like you see on dimensional lumber. So counting the teeth per inch should work just fine. A fairly easy way to know for sure though: bring either the wheel or the nut to a hardware store - Home Depot, Lowes, Ace, etc. In the screws/bolts/nuts isle there is usually some sort of display plate with numerous threaded rods and sample "nuts" to fit your mystery nut/screw onto. The sizes are printed on the display plate.
      The Rockler screw-mounted teenuts look interesting; I hadn't seen these before myself: http://www.rockler.com/product.cfm?page=1641
      Off hand though it looks like they're too small in diameter; if I remember correctly the mounting stud for my casters (also from Rockler, the one in the city of Orange) were at least half an inch in diameter. Those screw-mounted look a lot stronger than the usual teenuts with little teeth poking into the wood.
      Your idea of using a large hole in a second 1/2 inch thick sheet of ply to surround/cover the nut & stud portion makes perfect sense to me. Had I had a large Forstner bit at the time I would have done that too; that would give me a little more vertical clearance between the bottom shelf of the cabinet and the next shelf up. Maybe 1/4 to 1/2 inch... possible retrofit job now that I do have the right bits...
      mpc
      • Bruce Cohen
        • 2698
        • Nanuet, NY, USA.
        MPC beat me to it, or if you're really allergic to HD, Lee Valley sells a Screw Checker, which of course I just had to buy (impoverished tool junkie)
        The way screw measurements are stated; the diameter is first, followed by the threads per inch (tpi)
        A better view
        Hope this isn't more info than you wanted
        Bruce
        Samuel Colt did"
        • Anna
          • 728
          • CA, USA.
          MPC, thanks for the info. I agree that the t-nuts are probably too small. I also counted the number of turns in the screw, and I got 12 per inch. It looks like something I can probably use later, though. And it does look nifty.
          I'll try the other idea instead (with the plywood over the case bottom ply). I like Tom's suggestion of using fender washers, too. I just hope the whole assembly will be structurally stable.
          The more info, the better. Except for my husband. He's been cursing the day I found BT3central. Our credit card bills show mostly Home Depot, Amazon, and WoodCraft charges now. We went a-hunting for Herc-u-lifts in Sacramento yesterday, and he wanted to know where have I heard of these things. I told him it was posted by someone at BT3. After we found two, though, and he figured out what they're for and how much they were originally, he's convinced I got a good deal. So maybe I'll make a convert of him after all.
          Anyway, that screw size determining widget looks pretty nice and convenient. Will check WoodCraft and see if they have it.
          Thanks again.
