Push-down clamp source?
  • AlanJ
    • 150
    • Rochester, MN
    I have several jigs still on my to do list, and each requires two push down clamps. Rockler has the small ones at $12 (http://www.rockler.com/product.cfm?page=10397), and the larger ones are $17 each, which can get spendy pretty quickly.
    Does anyone know of another source at lower cost?
    Alan
  • bigsteel15
    • 1079
    • Edmonton, AB
    try here
    http://www.houseoftools.com/subgroup...40&orderfield=
    As far as I know, they do ship to US.
    Brian
    Welcome to the school of life
    • DonHo
      • 1098
      • Shawnee, OK, USA.
      Not sure if the size is right for what you want to do but HF has a similar clamp with a "T" handle for less than $6. I've used them on jigs with good success.
      DonHo
      Don
        These are some similar ones for $4.50 each discussed recently.
        http://www.bt3central.com/showthread.php?t=19984
        • AlanJ
          • 150
          • Rochester, MN
          oops.. posted this in the wrong thread...
          Thanks for the replies everyone. I found some on e-bay that fit my needs...
          http://cgi.ebay.com/New-Hold-Down-Vert-Toggle-Clamp-w-spindle-FC-33L_W0QQitemZ7585574085QQcategoryZ66916QQcmdZViewI tem
          They look similar to the Rockler ones and certainly big enough (4" clamp arm / 500lb)
          Ordered 6 at $4.00 Shipping was high, but still a good deal.
          Alan
          • hobkirk
            • Jul 2005
            • 85
            • Acton, MA, home of the original Minuteman - about 20 miles West of Boston
            I am thinking about the same issue... maybe these ideas will help...
            One possibility - use screw down knobs or cam clamps with hold down bars - they work better / worse depending on your application. The cams cost $7 (they were under $4 last month) and the hold down bars are $4 at Rockler. Or you could make your own hold down bars... Hold Down Bars and Cam Clamps
            ...OR...
            I was very impressed by the recent Drill Press Table thread (thread)
            It started me thinking about making the hold down clamps easily transferable [bear with me - I'm making this up as I go] -
            First, I think that I would only use any particualar jigs occasionally, but when I used it I would probably use the same jig repeatedly.
            Second, I liked the flexibility of locating the hold down in JWaterDawg's table, and
            Third, maybe I could design my jigs w/ T tracks or other hold downs that made it a snap to move a mounted hold down (whatever style) from one jig to another
            ...OR...
            maybe I should start taking my dementia meds!
            Doug Hobkirk
            WOOD LOON
