dowels strong enough?
  • jp
    • Jun 2003
    • 32
    • Watertown, MA, USA.
    I want to build a mobile base/cabinet for my BT3. I don't have the extended rails so it'll just be a box under the saw.
    Question: i plan on building it out of glued up panels of 3/4 inch plywood. Will dowels for the butt joints be strong enough to support the saw?
    thanks
    Glue should provide the bulk of the strength in such a joint, if the glue is properly applied.
    Dowels help in initial alignment.
    If you need a stronger joint then a joint that increases the glue area and directions will be stronger joint, for example, a rabetted joint.
    • RainShadow
      • 392
      • Oceanside, CA, USA.
      Plywood is tricky when using butt joints -- even Baltic Birch.
      Do you have a router ??? Dado/Groove/Rabbet the top/bottom of the carcass for a nice clean joint and then put it together with the help of finish nails.
      Good luck, Randy from Oceanside, CA
      • Rob R
        • 256
        • West, Michigan.
        i would second the rabbet joint. it's easy to do-- even with the cheapest of routers and a straight bit from MLCS (very inexpensive if you need one). that will give you a bunch of glue space and help keep the panels in place while you "tack it with a few brads" a la nahm abram...
        • Hoover
          • 1273
          • USA.
          Agree with the above posts. A butt joint is the weakest joint, especially for a mobile base/cabinet. There is not enough strength to resist racking when the base is being moved. A rabbeted joint is much stronger. Good luck with your project.
          No good deed goes unpunished
          • wassaw998
            • 689
            • Atlanta, GA, USA.
            jp -
            I found on my BT31 that as I moved the saw around my basement floor (which is rather unlevel) on the supplied stand, the saw would rack, and come in and out of alignment. To prevent that, I also built a very simple mobile base like you describe out of 3/4" ply + MDF. I rabbeted the joints, and included a center divider (dadoed) of mdf for more stabilty, and back out of mdf (rabbeted). I then mounted the 'box' on a platform, which was again a sheet of mdf and a 2x4 torsion frame. The idea was to have a very solid box that would not rack on me. I added a face frame to the front. You can find a picture of what I did over on the BT3 related discussion section, plus, a search would reveal a lot nicer looking ones with more ideas. Good luck !
            Chris
