Still in the thinking stages of building a shop in the backyard. I called the county and found out that anything over 150sqft needs a building permit.
I didn't ask anything about inspections, but I assume they would require several inspections along the way (footings, construction, electrical, etc). I had really hoped to avoid getting inspectors involved. I've never built anything more than a deck, so I don't have any experience with doing things to code. Knowing the weight of what is going in, I'd be more likely to 'overbuild' than to skimp.
On the other hand, I would hate to build something without the proper paperwork and have it come back to bite me when it comes time to sell or with my next property assessment.
Anyone who has built a shop, or is planning to build one, did/will you go the permit & inspections route? Or did you do it on the sly knowing you'd overbuild it anyway?
If you built without the permit/inspections, did you run into any problems further down the road?
If you built with the permit/inspections, did this increase construction time and cost any? How much research did you have to do? Would you go that route next time?
Thanks for sharing your plans and experiences!
twistsol
