Updated Shed pics (lots)
  • OldJeff
    • 139
    • Oakland, NJ, USA.
    #31
    Maybe down under that is a shed - here in Jersey that qualifies as a house
    Live every day as if it were your last, one day you will be right.
    • JeffW
      • 1594
      • San Antonio, Texas, USA.
      As always an inspiration to all of us. The problem is not to let LOML see it.
      Measure twice, cut once, screw it up, start over
      • MikeCrosa
        • 34
        • Ocala, FL, USA.
        WOW!! Cleaner than some hospitals I have seen. Going to use a lot of the ideas shown here. Thanks for sharing.
        Mike C
        • Tom Slick
          • 2913
          • Paso Robles, Calif, USA.
          • sears BT3 clone
          #34
          I aspire to someday have a "shed" like yours. right now mine is exactly the opposite of yours.
          • beetee3
            • 127
            • The Sunshine State
            #35
            Aha! So it's true that the sawdust falls upwards in Oz. I bet his shed ceiling is as caked up as my gar^H^H^Hshop floor. []
            • RodKirby
              • 3136
              • Mao Shan TSC-10RAS
              #36
              Maybe not. Check this thread out...
              http://www.bt3central.com/forum/topi...TOPIC_ID=20893
              Downunder ... 1" = 25.4mm
              • pierhogunn
                • 1567
                • Harrisburg, NC, USA.
                #37
                thought I saw some dust around the mat at the workbench, tsk, tsk, tsk
                No dust = ok
                lots of dust = ok
                little bit of dust = not ok
                Dan
                Monty Python's Flying Circus
                Dan in Harrisburg, NC
                  I've said it before and I will say it again. I don't think you actually build anything there. It is way too clean. If I kept my shop that clean I wouldn't have time to do anything except clean it.
                  • RodKirby
                    • 3136
                    #39
                    Also for the record...
                    • Habe
                      • 164
                      • Indianapolis, IN, USA.
                      • 22114
                      #40
                      Rod
                      Looks like you had to raise the disk sander stand a bit. I like how you did the raise, looks very sturdy. How do you have the grinder mounted, is it on a stand or wall shelf? If it is on a stand could you post a pic?
                      Habe
                      • RodKirby
                        • 3136
                        #41
                        quote:Originally posted by Habe
                        Rod
                        I wondered if anyone would spot that - well done!
                        When I had to round all the ends of the DP DC "scoop" (12 corners!), I was reminded that 1) The sander has always been a little low and 2) My back is a whole lot older than when I first made it So...
                        1. Decide how high to raise it - this took the longest time
                        2. Cut the 4 new "extenders", drill the holes in the ends for the 3/8" leveling feet t-nuts.
                        3. Cut the 1/4" marine ply "joiners", drill the mounting holes.
                        4. Glue/screw the joiners and extenders together.
                        5. Tip the stand on its back, remove the leveling feet and the t-nuts.
                        6. Tap the t-nuts into the new extenders.
                        7. Glue/clamp the new extenders/joiners to the old legs, and when dry...
                        8. Screw the joiners to the old legs.
                        9. Clear finish to match the stand.
                        10. Screw in the leveling feet.
                        11. With a helper - lift the stand upright, NOT using the legs as a pivot.
                        The grinder is on a wall shelf.
                          Bah. What I need is some video of you in action. You coulda built that cabinet anywhere. Very nice work on it BTW.
                          • charliex
                            • 632
                            • Spring Valley, MN, USA.
                            • Sears equivelent BT3100-1
                            #43
                            WOW I'm speachless.
                            • Knottscott
                              • 3815
                              • Rochester, NY.
                              • 2008 Shop Fox W1677
                              #44
                              You really SUCK you know that?! [)] Our guest bathroom isn't that clean!
                              Awesome "shed"......your shop must be amazing.
                              • RodKirby
                                • 3136
                                #45
                                Scott - I don't have to chase after 6 kids!
