Box (finger) joints - table saw or router
    • 8789
    I didn't mention a primary reason that I prefer router dados over saw blades. My router table has two routers on it specifically for when I am doing a project and have the need for one particular bit, but need to change bits for a second need, - it allows me to keep one bit for the main blade cut and the other router to change out. I HATE SWAPPING BLADES back and forth in the middle of a project, therefore I can have the best of both worlds with the dual.
    IF I had the FrankinSaw - for old timers that alludes to one guy who put 2 BT3x00s side by side on the same stand, and a few others followed - with that I could keep one standard blade an use, and use the other saw for dado. AS surely as I made a few dado cuts, I would need to rip another board to finish all of my dados - MEANING either have a Frankinsaw or change blades in the middle of a project.
    Even on my lathes, I changed out the motor on my first one so that I didn't need to keep changing the belts to change speeds up and down on a single project.
    • GrumpyDad
      • Jul 2020
      • 166
      • Midwest
      Hank: Would you consider posting a picture of your router setup?
      Harumpf!
      GrumpyDad
        • 8789
        I have photos in my media file on this forum but can't seem to get them to come up for this post.
        I'll upload from my computer again - hopefully.
        Below is the one that I made when I lived overseas in Osaka, Japan. It took up too much space to bring back when I moved back home (MS) so I gutted it and brought back the router bits drawers and in the past three years have started building a new one here. The new one is now functional but not as complete as the one in the picture, and is the same size 36"W, 21" Frt to Back, 41" tall with rollers. In the original below, I was originally intending to put 3 routers in, but finally decided that two was all that I needed. Also the one below has a 1/2 in router and a 1/4 inch router. The new one has two 1/2 inch routers Old but workhorse Craftsman and a VS PC.. I haven't finished my raise/lower arms yet, but I am working on it. There is very little difference in design in the old and the new, but some minor function changes. ON the new one, all vac is in the fence where as in the one below it was dual fence and router housing base.
        OH and on the one below, I don't have a a picture, but I had a backing on it that raised and lowered with an adjustment wheel which had a horizontal router on it. I used the horizontal router a few times over there but haven't had the need for one here. It could be easily modified for a horizontal router as the depth (front to back) has more than enough space. Also on the new one, the two parts drawers below the bits drawers were increased in depth by an inch. I had to move my 1/4 inch bits there as I needed all three of the bits drawers for 1/2 inch bits once I moved back home. I had about 40 -1/2 inch bits here in the States and about 60 - 1/2 in over there (but about 40 at the time of the photo), in addition to 1/4 inch bits. I now have about 150 bits total.
        Click image for larger version  Name:	2 Router Front.JPG Views:	0 Size:	158.8 KB ID:	843675 Click image for larger version  Name:	Viewing routers.JPG Views:	0 Size:	142.9 KB ID:	843676 Click image for larger version  Name:	Bits drawer.JPG Views:	0 Size:	160.7 KB ID:	843677
        • GrumpyDad
          • Jul 2020
          • 166
          • Midwest
          Thank you. I find the multiple mounted routers a very interesting option. Seems like they keep showing up here anyways.
          Harumpf!
          GrumpyDad
            • 22037
            Seems like two routers but just one shared fence is a very limiting factor???
            Unless you use the second router as a bearing guided for edge routing.
              • 8789
              Actually shared fence is not a problem at all. It does not matter to change the orientation of the fence for either one. The bearing is the ultimate limiting factor when using bearing guides. I do not use two router bits in tandem for unique cut, just each one individually. The primary purpose is so that I can set one to the correct height and leave it set, and then use the other - for other needs. Since the cutting is round and limited by the bearing on top as already mentioned, the fence could swing into any direction relative to the one bit that is doing the cutting. That is what I do. I usually swing the left side completely over the left router bit and leave the right bit exposed as much as needed for cuts, rabbets or dados. The fence on router tables do not have to be parallel to the blade or front table edge as it does in sawing.
              Let me say this in a slightly different way: I only use one bit at a time in relation to the fence, and since the bit is vertical and round, I can technically orient the fence from any direction to that one bit. All that is needed is the distance of the fence in relation to the bit.
              \ _ . _ . _
              So, why use two routers/bits? ON any given project, I usually use two and sometimes 3 bit shapes. On a single router table, and me not being able to see a few hours down the road, I would have to take the one set bit out and replace it and then take it out and put the original bit back in, and then do it again. BUT with dual, I don't have to keep switching bits. With a swinging fence, Cover one for one cut and swing it again and cover the other. The fence stays mostly in place but swings just enough on its track to cover one and expose the other and then vice versa. It is not as complicated as it seems in writing and is quite simple.
              The miter track does lend itself to the need in some cases to have an accurate parallel fence. But that is another story and not as often used - for me.
