Financial priorities my wife and I set are leaving zero room for a new car payment, I.E. I have to keep the old cars we have going unless there is a catastrophic loss such as collision, flood, or theft...
In that vein, my 2001 Saturn SL2 has been a bit of a clunker for the past few years, squeaking this and that, which led to a howling belt last April (14), and we opted to park the car and work on it slowly. Fast forward to 2 weeks ago, and my 2004 F150 5.4L has a decided cam timing problem. I had the parts for the Saturn, I knew what to do...
Bust my hump and get it running.
So over the course of the last 2 weeks, weekends included, I replaced basically ALL of the spinning mass from the front of the engine on my Saturn. That includes.
#1. Air Conditioner Cmpressor clutch.
#2. Water pump. (It was leaking).
#3. Power Steering pump. (It was growling).
#4. Drive Belt Tensioner.
#5. Drive Belt Idler pulley (The bearing was literally falling apart).
I figured out some new tricks nobody else online was posting for getting to the bolts due to the extreme proximity of the front of the engine to the side of the car. For those with one of these, or similar cars, what I did was I put a floor jack with a 2x4 brace under the oil pan, and supported the engine, then pulled the passenger side motor mount. I then pushed the engine up about 1.5" with the floor jack and voial! The inaccessible bolts were easy to reach!
I managed to have to replace the battery on the car to get it going. Although I had it disconnected, and would put a tender charge on it every couple of weeks, I ended up with a bad cell. It happens...
Lastly, I did an oil change on it. Not happy with the lube shop I had taken it to last 2 times. The oil filter I used 3 oil changes ago was still on the car, INCLUDING my sharpie marks! I know Saturn oil filters are a pain to get to, but I was paying someone else to futz with that, never again!
With it all back together, it flew through inspection, and runs like a top. I cleaned my rotors from the surface rust via a scotch brite pad , and we are going great!
Saturday had us doing some parts hunting. I tracked down a good pair of front seats from the car coming out of a Garage kept 2002 SL1, and a rear spoiler from a 99 SL2. (The 99 trunk / parts fit the '01 thankfully!).
I need to head over the HF to get some fine sanding pads for my DA sander and get after the peeling paint on the hood and trunk. Most likely strip the entire car down, and take it to my BIL's shop to have him shoot it a candy burnt orange. About the only color LOML and I can agree on with this car.
My week nights, assuming LOML doesn't plan them out for me, are going to be some HEAVY duty shop cleanup. It's a disaster with stuff all over the floor, table saw, work benches you name it, if there is a horizontal surface to be had, it's messed up. LOTS of tools need to go back where they belong.
Once I get the area cleaned up, THEN I have wood / cabinet projects to get on / back on.
