It's square, but it isnt, but it is.....totally confused
  • sailor55330
    • Jan 2010
    • 494
    Hi-
    I'm building a basic wall cabinet using face frame construction and I need a sanity check. I just completed the box/shell and I am totally confused. Obviously, I want it to be square, so I take time and make several checks.
    I measure diagonally and the measurement less than 1/64 of being dead on---I can live with that.
    I put my square (confirmed square btw) on each of the outside corners. Corner 1, 2, and 3 are dead n**ts on. Corner 4 is about 1/8 off.
    I put my square on the inside corners, exact same story.
    I measure diagonals and again, less than 1/64 by the tape, both directions.
    So, is it square or not? If so, what's driving the weird 4th corner reading? Common sense tells me it's impossible for 3 corners to be square and the 4th way out of whack.
    Would this bother you? It's driving me nuts and frankly this kind of thing is why I walked away from wood for about 2 years.
    Thanks for the vent.
  • All Thumbs
    • Oct 2009
    • 322
    • Penn Hills, PA
    • BT3K/Saw-Stop
    Trust the diagonals.
    You probably have a bit of bow in the top, bottom, or one of the sides.
    • jussi
      • 2162
      My guess is the sides are bowed. Happens a lot on larger cabinets (ie kitchen cabinets). Is the back glued to the sides and top. obviously need to use plywood or non moving piece. Ie non solid wood. But even then the front can still bow. In which case face frames or better yet a fixed center shelf will help.
        +1
        However, you may have made a trapezoid in which case your diagonals could be equal but your corners won't be square. Check that each of the opposing sides is equal in length, too.
          • 22061
          I'm thinking it may be a warp or bow in one of the sides, too.
          • sailor55330
            • Jan 2010
            • 494
            Thank you all for the quick responses. I looked at it again and believe it to be a slight bow in one of the sides. It's barely visible if you are looking for it. I don't think it will be enough to hinder the project, especially when the faceframe goes on.
            • lrr
              • 380
              • Fort Collins, Colorado
              • Ryobi BT-3100
              A 4-sided object has interior angles that sum to 360 degrees. If 3 are truly 90, the 4th must be 90. I would agree with others that a bit of bowing is probably throwing off your angle checks.
                I didn't see if the cabinet was solid wood or plywood. Plywood, besides bowing could have a spot where the thickness varies (void, too much glue or something extra like a splinter that thickens an area).
                Solid wood, less likely to have extra thickness (probably would have spotted that), but could be bowed (cut just a tad longer and bowed to fit).
                  • 22061
                  Lay a good straight edge along the side ... you should easily be able to see any bow.
                  • sailor55330
                    • Jan 2010
                    • 494
                    Again-thank you all for the responses.
                    I am happy to say there are no weird anomalies or variances in the box that could upset the progress of String Theory or any other major laws of physics as we know them.
                    The case is made of particle board, so most likely a variance or slight bow.
                    Again, thank you for the help and realization that on a scale of 1-10 in WW, i'm about a 0.6, but trying to learn.
