Shadowbox for Fireman's Axe
  • bmuir1616
    • Dec 2008
    • 28
    I've been asked to build a shadowbox to hold a ceremonial axe for a retiring firefighter. Size is 38" H x 24"w x 3.5"D I will mitered corners and add blind splines for strength.
    I plan on building it from 3/4" oak 1x4s with a 1/2-inch back because the axe will most likely be screwed to the shadowbox from the back.
    Questions:
    How would you dress up the 3/4-inch edge that is visible? Simple roundover? Bevel? Other ideas?
    Also, any ideas on how to best hold this big a box with mitered corners together while the glue dries?
    Thanks.
  • greenacres2
    • Dec 2011
    • 633
    • La Porte, IN
    In my mind, the ceremonial axe should be the focal point--in homage to the life of service, so i'd vote in favor of just easing the edges. Nothing fancy needed.
    As for clamping--i'd probably use a strap clamp.
    earl
      • 3791
      Finger joint corners, attach the ax in place using screws through the back plate.
        I would leave them unadorned, or a simple bead if anything. You could make wood corner clamps like this (not my photo).
        • RAV2
          • Aug 2007
          • 233
          • Massachusetts
          • 21829
          Check these ideas out:
          http://shadowboxusa.com/242/fire-ser...w-box-gallery/
          • sweensdv
            • 2873
            • WI
            • Baileigh TS-1040P-50
            Bullnose router bit for the face and +1 on the strap clamp.
              Part of me is saying have some fun with it. Make a locking door frame that will hold the (plastic, unbreakable glass) with the In Case of Emergency, Break glass. Hold the axe in with a leather strap and a leather cup.
              Found a basic image, doing a search: http://tvtropes.org/pmwiki/pmwiki.ph.../DeusAxMachina
                I like that idea! As to trim profile, I would agree with others to stay simple and have the axe as the focal point.
                The best band clamp I have found for large frames is the Merle from MLCS.
                http://www.mlcswoodworking.com/shops...rle_clamp.html
                • gsmittle
                  • 2793
                  • St. Louis, MO, USA.
                  +1 on the Merle! Great clamp!
                  g.
                  Smit
                  "Be excellent to each other."
                  Bill & Ted
