The stile of the FF is usually wide enough to glue to the side member, and part of it glues to the leading edge of the top and bottom of the cabinet. IOW, it catches the joint between the vertical end, and the top and bottom of the cabinet. So, in essence, that cabinet joint at the front has a single piece of wood covering it. The actual joint of the stile and rails is beyond the cabinet member joint.
Once the rails are glued and clamped to the stiles, and glued to the leading edge of the cabinet, you have the rigidity in place from the stiles to the end panels, and from the rails to the top and bottom. So, a butt joint @ the R&S, is sufficient when clamped. That fitment can be a better joint if just done that way instead of reducing the surface glue area by using a biscuit or two, or using pocket screws. There's always a chance that the two surfaces brought together as a butt joint and mechanically fastened with pocket screws can fail. Pocket screws pull from one side, or IOW, at a slight angle. That isn't as an effective tightening axis as just a clamped joint. You will never have a breakout from a protruding screw, split ends or cracks, that pocket screws can produce.
With this type of joint being just glued and clamped it will likely never fail. If a cabinet can be racked enough to break the glue joint, there is likely a very poor job done with the method of assembling the cabinet members.
