I am making a "five board" bench as I need a quick Christmas present, and these look fairly quick and easy to make. I know Charles Neil shows a finishing technique in his video, but I don't want to artifically age or distress the bench. I want a new bench that time and use will distress. I am using Poplar because I saw a board with nice white wood on the outside and the green wood in the middle, and I though it looked pretty. I do not want to stain this or dye it. All I want to do is put some kind of protective clear shiny finish on it. What do you all recommend? The bench may go outside, but it will be under a big covered patio.
Glossy finish for Poplar
I might agree with chop. Since you want it shiny an oil base poly would likely be the best bet. But if it's exposed outdoors or to the elements, a spar urethane might be better. The down side`to the spar is that it's softer than a non spar urethane, and takes a long time to cure...several weeks.
.Comment
If you decide to go this direction consider General Finishes water base poly. Dries quick like lacquer, but has uv stabilizers in it. I think lacquer outdoors subject to vast temp swings might crack. Maybe Jdon will post again if he has used this for outdoor projects.Last edited by chopnhack; 12-15-2012, 07:04 PM.I think in straight lines, but dream in curves
- you're absolutely right- water based poly is a better option.
