Trouble spraying acrylic
  • ivwshane
    • 446
    • Sacramento CA
    I'm at the final stage of finishing my laundry room cabinets and I successfully sprayed the primer without thinning.
    http://www.kellymoore.com/products/ps_295_uni_primea
    Now I'm trying to spray the final coat (dura poxy) and it just wont flow out with any usability.
    http://www.kellymoore.com/products/p...nex/dura-poxy/
    The paint appears to be thinner than the primer so I don't understand why it wouldn't work. I'm using this harbor freight gun:
    http://www.harborfreight.com/air-too...gun-92841.html
    I have adjusted every knob possible and the best I get is a very fine mist that barely leaves any paint on the surface. I have also adjusted the air pressure at the compressor with no luck.
    I know I can thin it with water or floetrol but I just don't understand why it wont work and why the primer did.
    Is there gun that I can spray the acrylic with without thinning it that will give me good results?
    Sure but it is a lot more money. My Fuji mini mite 3 should do it but it costs over 500.
      You can use an ordinary siphon gun, or an HVLP. I've tried the LVLP guns and don't like them. That gun should shoot that media. Something my have plugged up the fluid flow, needle,tip. If the previous media has dried at all in the gun, use lacquer thinner to clean. Run it through the gun after cleaning the individual parts, and adjust fluid flow to clean it out.
      • ivwshane
        • 446
        • Sacramento CA
        Do I need more air pressure? That's the only thing I didn't try but the last time I did too much air pressure I blew the can up
          • 2807
          I've had mixed results spraying acylic latex, but for the most part have been rather successful.
          I've used only siphon feed guns, and have not yet tried an HVLP. I've used that little "touch-up" spotting gun (like pint-size container with overhead trigger) with good success and also a C-H siphon gun. Both have 1.8 mm knozzles, so I would certainly think your gun with a 2.0 mm nozzle should work even better.
          I see the specs say to use 20 psi. Frankly, even my little air brush requires more pressure than that, so it doesn't seem quite enough to lift a heavier acrylic. I generally use about 45 psi in either of the two guns I described. Certainly not too much higher.
          It sounds like there's some kind of restriction somewhere. Is the vent-hole open? You've had success with the primer with this gun, so something must have happened since then, I would think.
          First thing I would do is dump the acrylic out, add thinner (water) to the container and see if the spray clears and is sufficient once again. If not, clean the gun and it's passages thoroughly.
          Is your acylic well mixed and without any debris or lumps (pour it through a course screen if necessary).
          Good luck,
          • ivwshane
            • 446
            • Sacramento CA
            It must have been a clog because now it works, sort of I think I broke the sprayer trying to clean it.
              That's good news...sort of.
              • ivwshane
                • 446
                • Sacramento CA
                What can I say, I'm an idiot
                One would think that the siphon tube would be threaded and easily removed, nope:|
