Plywood or MDF for a Jig
went with the plywood - figured I had it on hand. It is partical board - I picked it up at a Habitat for Humanity restore. If you have not visted one - you may want to - esp if you need smaller stock - they have cabinet doors, moulding, misc board stock, etc - a lot of builders dump left-overs there. Just my $.02Beaux Ti -
If you see a Bomb Tech running, follow him....Comment
We have a large HFH Restore here. There is usually a large selection of cabinet hardware, new, like full extension slides for $1 a set. Euro hinges & plates for 50 cents.went with the plywood - figured I had it on hand. It is partical board - I picked it up at a Habitat for Humanity restore. If you have not visted one - you may want to - esp if you need smaller stock - they have cabinet doors, moulding, misc board stock, etc - a lot of builders dump left-overs there. Just my $.02
.Comment
Not all Melamine sheetgoods have a particleboard core. I picked up a sheet of MDF core 3/4" White Melamine a few years ago from Lowes. It was a really stupid idea for an outfeed table top, so I turned it into a drill press cart. http://www.bt3central.com/showpost.p...07&postcount=4ErikComment
It was a really stupid idea for a portable large outfeed table. My 21829 gets moved at the end of every day.
My stepson had helped me load and unload it in his truck when I bought it. When I went to break the 4x8 sheet down to size I was alone. I ended up taking my sawboard and sawhorses to it rather than move it to my shop. It still didn't dawn on me how impractical the 3/4 MDF was for portability when I was breaking it down. I finally called myself an idiot when I was trying to manhandle half the sheet to my shop. Even 1/2 size it was extremely heavy.
This worked much better than 3/4" MDF core Melamine: http://www.bt3central.com/showthread.php?t=41179ErikComment
"went with the plywood - figured I had it on hand. It is partical board"
which was it, particle board or plywood? Two very different materials. Gotta be one or the other.
sorry - sometimes too frugal with words -- what I meant - I went with the plywood for sacrificial material and yes the melamine was particle board not MDFBeaux Ti -
Footer Ad
LCHIEN
At least that hollow core door assembly fits the bill better.
