Trimming Laminate
  • Denco
    • 426
    • Coming soon: California
    Trimming Laminate
    I glued a piece of laminate to a 2'x3' table top. I cut the laminate a little larger than the table top to ensure coverage (large enough, bad aim, etc).
    Anyone know a good way to trim the laminate? The table top is currently upside down on my project table.
    No funds for any power tools right now. Would a utility knife work? The laminate seems slightly flexible but kind of brittle to me, but that could just be normal.
    Thanks!
    *****Measure twice, cut once.....rats, back to the lumber yard.*****
  • Daryl
    • 831
    A router and laminate trimming bit is the best way to go. Lacking that, carefully score with utility knife within 1/8 inch of edge, carefully snap it off and finish with a good rasp or file, drawing down against the table top.
    • Denco
      • 426
      Thanks. Does it have to be a laminate flush trim bit or would any flush trim bit with a bearing be appropriate?
        A flush trim bit with a bearing is for trimming the edge flush for laminate or wood. You do need a smooth edge without indentures or high spots for the bearing to track straight.
        • Denco
          • 426
          Excellent! I have a flush trim bit w/bearing for my router. I've got a smooth edge, so I'll give it a shot in the morning.
          Thanks to both of you, Gents!
          • phrog
            • Jul 2005
            • 1796
            • Chattanooga, TN, USA.
            How do you trim inside corners, C'man?
            Richard
              Punch a hole in the laminate, and feed the bit through.
              • Denco
                • 426
                I trimmed the table top today and your advice was right on the money. The job went great using the flush trim bit. Thank you again for the help.
                  You passed up a good excuse for a new toy. One of these would have helped, or a colt.
                    This would be a better deal, IMO.
                    • Denco
                      • 426
                      It's only a good deal if there's $$$ in the tool fund.
                        • 22074
                        But you saved $XXX by doing it yourself...
                        • Denco
                          • 426
                          Y'know, Loring, ya make a great point there!
                            Laminate trimmers are great little routers. They can do light profiling on wood. They can be handled with one hand which makes them easy to use.
