Anyone ever route plywood? Does it route okay? I need to put a lip on the inside of a hole in 3/4" plywood.
Routing plywood?
*****Measure twice, cut once.....rats, back to the lumber yard.*****Comment
If you already have the hole, and want to make a step at the top edge, you could just use a rabbeting bit with a bearing, like this. A handheld router would be used. How far into the face the rabbet goes can be set by the size of the bearing. For how deep the rabbet... is set by the router bit depth setting on the router.
The first pass can be a shallow one to score the surface veneer, and then the depth. I would recommend a carbide tipped bit, not HSS.
.Comment
