plywood optimization
  • SilentSam
    • Oct 2010
    • 22
    • Richmond, VA, USA
    Wondering two things. I have a project with plans that I can get four sets pieces from a single sheet sheet of 1/2" ply. I am making 40 of these boxes, possibly more. I can only wonder if any of the software optimizer can calculate out a more efficient cut list when looking at the total desired outcome. So my question is this. Have you used any of the "free" software out there that might support a project like this?
    At $22 dollars a sheet it would be nice to stretch the dollar a bit.
    Also should anyone have purchased the software and would like to plug in my cut list, I will gladly send you the plans. Thanks,
    SS
  • Cochese
    • Jun 2010
    • 1988
    I've got cutlist, just give me the dimensions and the quantity and I can run it through real quick.
    • SilentSam
      • Oct 2010
      • 22
      • Richmond, VA, USA
      http://robo.bushkillfarms.com/downlo...s5FrameNuc.pdf
      Thanks!!!!!!!
      SS
      • Cochese
        • Jun 2010
        • 1988
        Even estimating the entire project, at a 1/8" kerf and true 48"x96" panels, you're still using 10 sheets. You're only using a very small portion of that 10th sheet, but the cost is still there.
        If the plywood is 48.5*96 or 48*96.5, you can do it in nine. If not, do it whichever way you want to.
        This is assuming crosscuts first, as is the standard.
          • 22108
          FWIW, doing the original way e.g. 4 from a single sheet of plywood might give you more uniform grain pattern, e.g. all like pieces will have a common grain direction?
