Quick and Easy finish?
  • jussi
    • 2162
    I'm a finishing noob and need suggestions on a quick and easy finish to use. Making a dollhouse for my niece for Christmas. Some of it will be painted but others I wanted to put a finish on it. Those parts include walnut floor and doors and cedar roof. I have a Rockler spray gun I got a while back but never used. I'm tempted to try it out but not sure I have the time to be experimenting. Should I just stick with a wipe on and if so what?
    Thanks
    Bullseye spray shellac and Deft spray acrylic both go on easily and dry very quickly. The shellac provides a warm yellow tint. The acrylic is clear.
    Minwax wipe-on poly is also clear and dries in about 2-3 hours.
      • 22106
      real easy finish is just a few coats of tung oil or even the tung oil finish (with a little varnish thrown in) from Formby's.
        I've had good luck with the brush-on water-based polys; they dry fairly quickly, and you can get a couple coats on in a short time.
          The acrylics and polys won't bring out the grain and chatoyance like an oil would on the walnut, but time is getting short. I've always had good results & looks with danish oil.
            Another that won't enhance the wood, but is easy and quick is Deft spray laquers.dyies almost of contact.
            • gsmittle
              • 2793
              • St. Louis, MO, USA.
              I'm a big fan of shellac, myself. Either the spray or Bullseye in a can will work. The can is a little thick for brushing or wiping—thin it with denatured alcohol first. There's a table on the side of the can for guidance.
              Dries very quickly, and additional coats stick to the previous coat with little to no prep. Easy clean-up, too.
              g.
              Smit
              "Be excellent to each other."
              Bill & Ted
              • jessrice
                • 161
                another vote for deft spray lacquer. First time using last Saturday, got six coats sprayed in 5 hours on an oak quilt rack.
                Looks good, smooth finish, no sanding between coats.
                Jesse
                • natausch
                  • Aug 2009
                  • 436
                  • Aurora, IL
                  • BT3000 - 15A
                  BLO and a shellac or other topcoat
