Cove Molding
  • Luckbox
    • 371
    • Holly Springs, NC
    Cove Molding
    I am going to make my own cove molding with a jig on my table saw. My question is would it be better to use a cross cut blade or a ripping blade. I am thinking ripping blade since there is more room between the teeth for the saw dust.
    I love lamp.
    I did a couple cove cuts on some red oak to replicate some long curved drawer pulls on a chest I was restoring. From everything I read, more teeth and sharpness was recommended. I used a new 80T crosscut blade I had. The results turned out well. There was just a little sanding to remove the slight ridges. A foam sanding block shaped to your cove radius will help, especially if you're doing a lot.
    The amount of sawdust won't be too much of an issue, as you will be doing multiple passes raising the blade just a bit each time. You can't hog it all out in just a couple passes since the cutters on your blade aren't that long.
      You could use either, but a crosscut blade will leave a smoother surface. I've used 60T with good results. The depth of cuts are very small.
        • 3791
        I have used the table saw to make several hundred lf of cove cuts for podiums and columns. The best results were with a new 60t freud blade. A lot of sanding was still required. All of my work was with #1 pine so a harder and better grade of wood should require less sanding. #2 pine and the lower grades required way too much sanding, so test your wood for the best results. For the finish I found that sanding the cove with a correct size sanding flapper wheel produced the best and quickest finish.
        capncarl
        • Sid
          • Apr 2004
          • 139
          • Bloomington, IL, USA.
          • Craftsman 22124
          I haven't done a lot of cove cutting, but I did do some tests comparing the result of the same cove cut in oak with an 80 tooth crosscut and a 24 tooth rip blade. There wasn't a lot of difference, but the rip blade left a slightly smoother surface.
          I figure that since the work is going somewhat sideways through the blade, it is doing a scraping cut, and the flat-top rip teeth will scrape more smoothly than the beveled-top crosscut teeth. Think of scraping with a chisel compared to scraping with an awl.
          On the other hand, having more teeth would mean the scrapes are closer together. Perhaps a combination blade with higher tooth count and some flat-top raker teeth (typically 1 in 5 teeth) would give the best of both effects. I didn't do a test with a combination blade.
          Sid
          • Luckbox
            • 371
            • Holly Springs, NC
            Thanks for the help it looks like I am going to go witht he higher teeh count. I makes more sense, I was just wondering abuout the sawdut, but I guess since they are shallow cuts that it wont be as much as I am think in each pass.
            I love lamp.
              There's not large amounts of sawdust, but it is pretty fine.
              Sid- Good point on the FTG blades. I was wondering that myself. I just didn't have a decent shart one to try it out on. I noticed that if I did a slower feed on the stock the results were a little bit smoother.
