What makes Outdoor Poly Outdoorworthy
    OK folks what does outdoor poly have that indoor does not?
    Is it something that resists discoloration or does it have to do with ability to withstand the weather?
    I am refinishing an item of outdoor furniture and am now out of outdoor poly. I have a surplus of the indoor variety and am considering why I should/not use it.
    I dont care about any color issues with the item in question but mainly about protection from the elements. Given the harsh temps we have here I typically end up sanding down and recoating each year anyway so does it really matter?
    With an oil finish you wouldn't have to sand to recoat, just do a good cleaning. Outdoor oilbase polyurethanes, or spar varnishes, are basically the same but have a higher oil ratio than indoor versions, and have UV additives. The higher oil ratio is to keep the finish somewhat flexible to deal with expansion and contraction. They take a very long time to dry and don't dry hard.
      • 22039
      probably at least, UV filters built in to the formulation to protect the poly and the wood.
        What Cabinetman said about flexing. Spar will never completely dry or cure as in-door which gives it flex and the reason you should never use it on inside furniture. Frankly I would go get another can to finish. I used in-door on a mail-box once years ago and it had deterioted to the point of stripping down and re-finishing in a little over a year of exposure to the Georgia sun.
