More Maloof dresser. Roundovers defeated!
    I don't know what the fuss was all about with these roundovers. It was one
    of the easiest things in this whole project.
    Below is the world's simplest jig. A piece of extra melamine with a hole drilled
    in the middle.
    The router with roundover bit is screwed and double sided taped to the "jig".
    The melamine has to be large enough so the router can't tip. I just let the
    bearing ride against the inside and route away. One of the few times I use
    the fixed base.
    Nearly had a heart attack when I flicked on the router and it didn't start. A
    few Fonzie taps later and I was good to go.
    All the roundovers done.
    I've got a few flat spots to sand smooth.
    Using a chisel and round rasp, I made the joint more Maloof-like. Still have
    some more sanding to do. A bunch more corners to do. I just wiped on some
    mineral spiritis to show it off a little.
    Updates won't be coming as often now. I've got a bunch of sanding to do
    and I've started building the drawers. Right now just milling a bunch more
    wood for the drawers.
    Paul
    Last edited by atgcpaul; 11-02-2011, 01:51 PM. Reason: Google moved all my pics. Updated now.
  • jking
    • 972
    • Des Moines, IA.
    Looking good. Glad it turned out simple.
      Nicely done. Your melamine baseplate is pretty much what I thought it should be (once I abandoned the madness about rounding over prior to assembly!).
      • Hoover
        • 1273
        • USA.
        Thanks for the updates. The fine tuning of the joints really make it more visually appealing. Keep up the good work!
        No good deed goes unpunished
          That looks good, and it's always a joy to find out something is easy.
            Looks great. Great idea on the jig.
              Paul = genius! Great work on that, made a difficult and nerve racking task into a pleasant 15 minute job nice!
                Thanks guys. I wish I could take credit for this jig but Sassafrasman on Woodnet gave me the idea. I'm just a good listener.
                • jnesmith
                  • 892
                  • Tallahassee, FL, USA.
                  Paul:
                  Any chance of reviving this thread with the original pictures? For a long time I have been interested in Maloof designs in general, and his "Maloof round" in particular. I've often wondered when and how he shaped the rounds. Sound like you got it figured out.
                  Thanks.
                  John
                  • jnesmith
                    • 892
                    No luck with Paul. Has anyone else done something similar?
                    John
                    • unknown poster
                      • 219
                      I can see the pictures. Were they fixed, or can you still not see them jnesmith?
                        They weren't showing for me when John first posted about them. They are now though.
                          • 22085
                          you guys should thank paul, he edited his original post today (see note at end) and updated the pics.
                          • schloff
                            • 229
                            • Southern Middle TN
                            • Powermatic 64 (BT3000 RIP)
                            Thou shall not covet thy neighbor's router. But darn, I would love to have one of those.
                            The work looks great, too. well done.
                            • jnesmith
                              • 892
                              Indeed. Thanks Paul! Much better info on this process than can be found anywhere else on the net.
                              John
