This looks like it came from my ROS. I use a PC 333 sander. I had not noticed this before on this project. I thought maybe it was the new norton sanding discs that I just started using. But, I saw the same thing on a piece that was sanded with the old discs. I was using an 80 grit to do the initial sanding and then to a 320 for finish.
Maybe I should use one or two grits in between.
Or, should I get a new pad? The edges are a bit worn and it does not seem to be a very soft pad.
Salty
Salty
