Cutting circular parts
  • Bruce Cohen
    • 2698
    • Nanuet, NY, USA.
    As part of a jewelry box I'm starting, I want to use a circular piece of wood approx 1.25" x 1/8-3/16" thick.
    Does anyone know of a way to achieve this without having a pilot hole in the center of the "disk" as it will be standing on end as part of an ornament on the top of the box.
    BTW, I do have a drill press.
    Thanks in advance for your help.
    Bruce
    Samuel Colt did"
  • jziegler
    • 1149
    • Salem, NJ, USA.
    How about making a template (which would have the hole) and then using a router with a bearing straight bit to cut the final part? Use double sided tape to hold the parts together for the routher cut, or use a clamp and carefully rearrange to finish the cut.
      I'd probably just use my drafting circle template or a compass to draw a circle on the piece of wood and then take it to my scrollsaw and rough out the shape then sand it for the final shape. If I didn't have a scroll saw I'd use my coping saw.
      If I had a bunch to do I'd try it on my drill press with a wing cutter without the pilot bit and double stick tape.
      • phi1l
        • Oct 2009
        • 681
        • Madison, WI
        Long this line. I am trying to determine the best way to make a tapered hole. the hole is to be through a 1 1/2 think piece of wood with the small diameter 1 1/8" & the larger diameter 1 1/4". I am thinking of just using a router table with an appropriate wedge on the surface, and a long straight bit. Then starting with a straight hole of the smaller diameter, & a template as a guide, rotate the piece around the bit, hopefully maintaining a consistent taper.
        Anyone have any better ideas???
          As it's been said...make a template and use it to rout the final piece. Draw a circle and cut it with band saw, scroll saw, or a jig saw. The edge can be sanded round using a flat block sander made with sanding belts, and paying attention. Or, for larger circles, a pivoting trammel arm hot glued to the center used with finesse works pretty good.
            • 9562
            Do you have a lathe and miter saw? Make it round in the diameter you want, cut the thickness slice you want and done...
            I would imagine it would be a bit harder to do, but one of those drill press vertical lathe jigs might do the trick if you don't have a lathe...
              I should have added you could draw a circle and cut it with a coping saw. Just turn the blade 90 degrees to the frame, and then block sand round with the nifty type that I linked, or, use a sanding pad in a drill if you don't have a belt/disc sander, or secure the piece and use a belt sander.
                Use a hole saw on a drill press w/ the pilot bit removed. Use a high quality saw that doesn't wobble. I've done it a few times.
                BTW, you won't be able to hit exactly 1.25" because you have to account for the kerf of the saw. But you can get close.
