I have about 22 shutters on my house. We just bought it in July and have notice all of the shutters are rotting fast. Recent winds have caused two to fall off. Others are close to falling.
So I took one to my shop, reverse engineered it (sounds fancy) and have determined these are easy to build. I bought the right panel bits from MLCS and I just finished the first one (the prototype). Simple.
Now I'm ready to start cranking them out. I'm using basic pine from HD and Lowes. Each shutter has about $10 of wood. I, of course will use Titebond exterior glue, but my question involves the best way to make these things last.
I plan on priming them and painting them. But how necessary is it to prime them before I assemble? It seems if I don't, the grooves, etc will rot fast as they're not protected.
It's a basic raised panel design. Right now, the proto fits perfectly together, but if I prime and paint first, I'd have to compensate for the paint and primer. Or, maybe I should just run a bead of caulk or silicone or something.
I'd much prefer to assemble the raw wood shutters and them seal, prime and paint afterwards. Any ideas? Also, must the panel float without glue? Or can I glue it? I've never done an exterior project like this.
Here is a picture of the prototype...
LCHIEN
