Problem # 1: I'm doing some cabinets out of salvaged pecan that has worm holes and trenches that I want to retain into finality. On the 1st sanding they filled with compacted dust. I tried to blow out the dust with compressed air @ 90 psi with mixed luck; some did, some didn't. A previous test tells me that the trenches will stain differently if left, plus they might be unstable and come out later. Problem # 2: As I've gone through the sanding process using a palm sander with 90-220 in graduated steps I've noticed "shiney" areas. Some appear like fingerprints. It seems as though I should be concerned but even using the sander I have a difficult time getting all of these areas sanded rough. I'm not sure where I've gone astray and how to recoup. Any advice would be in these areas would be greatly appreciated.
