Trailer Sides
    Trailer Sides
    The time has come to replace the sides on my utility trailer. They are currently made of 1x4 PT and about 3' high. There is a top rail and a middle rail, so there are open sides. I've never liked that design since shorter/smaller pieces of lumber can slide out underneath the bottom rail unless they are tied down. Also, the bolts are about 1" too long and can scratch furniture, etc that is loaded into the trailer.
    I don't think I want solid sides - too heavy. I want a bottom rail that sits on the deck to keep small stuff from sliding out. I will also add eye bolts to this for tiedowns. Any suggestions after this? I carry the trash cans to the dump every couple weeks and use it for lumber, building materials, furniture, etc.
    I wouldn't put the bottom rail right on the deck. Raise it up 1/4" or so, to allow water to drain out.
    I'm not able to envision how everything bolts together (are there wood verticals? steel?), but you could maybe use carriage bolts with the heads on the inside to eliminate the scratching problem. In the shorter lengths you will presumably need, 1/4-20 carriage bolts are available in 1/4" to 1/2" increments, so they shouldn't have to stick out too far on the outside.
    • messmaker
      • 1495
      • RICHMOND, KY, USA.
      • Ridgid 2424
      I used PT plywood for the sides. They are not that heavy. The sides were maybe 35#.
      • L. D. Jeffries
        • 747
        • Russell, NY, USA.
        Had the same problem and cured it this way. 1/2" pt ply and just boxed the inside of the rails. Left about 1/4" space along the bed for water draining. 1/2" is light enough but still strong. Carriage bolts with heads inside to secure panels. Works OK for loose stuff as well as small things. Hooks at each bottom outside corner to ty down a tarp if needed.
        RuffSawn
        • jhart
          • 1715
          I wanted to have the sides on mine removable, as I stand the frame up for storage in the garage, so I made 4 sides out of 3/4" PT plywood and 2 X 4's going up the sides and corners. Each panel slides into the frame slot using the 2 x 4's. I found some corner slip in slots to tie the ends together. The panels get hung on the garage wall when not in use and the trailer can be used as a flat bed type or with the sides on if I hauling stuff.
          Not the best looking trailer with sides I've ever seen, but very functional. (I made it in the garage, during the Winter when it was about 0-5 above out, so quickness rules over form).
          During the Winter, I use it without the sides to haul a good sized snowblower around to my apartments. Made a couple of ramps out of remaining pt plywood.
            There are currently wood verticals. Spacing the bottom rail off the deck is a good idea. Thanks for the suggestion. I am still not sure I want solid sides but it would be easy and quicker to do. I don't want to reuse the existing sides, they really are falling apart. For those who have solid sides, how tall are they? I am thinking max 24" since that will let me build it with 2 sheets of ply.
