After many years of owning my BT and many weeks of thinking through what I wanted in my mobile base and table extensions I finally started work this weekend. As much as I would like to just get it all done in one go I think its going to take a few weekends to get this finished and thought I would start a thread and document the various build stages.
Weekend 1 - The Torsion Box.
Like many others before me I elected to create a torsion box base as the foundation. I looked at a few other bases that folks had made and liked the idea of using dadoes to aid with registration as Ray (UK) had done. Much thanks to Ray for a useful phone call on Saturday before I started cutting. To ensure everything goes together perfectly accurate layout is essential.
After cutting the top and bottom to final size I figured out where my long dadoes needed to be and marked them out the exact same distance from each edge. This way when the internal pieces are cut the two outside rows will be the same length.
Using the straight edge from the opposing skin I routed the long dadoes (thanks for the tip Ray).
Next having clamped the two skins together I carefully laid out for the cross dadoes and using an edge guide routed bothe skins togther so I could be sure the dadoes would be in identical positions.
Using a router edge guide I then added rabbets around both skins.
I glued and clamped the plywood blocks to what will be the topside of the tosion box to give me something more solid than the MDF to screw the cabinet carcass to. I also added plywood blocks to the 4 lower corners to help with the wheels.
Dry fit time. I cant tell you how many times a dry fit has saved my A$$ (I am sure you all have similar stories). In this case I came across my first GOTCHA. I am using 1/2" MDF for the internal structure and having routed 1/2" dadoes found them to be a perfect fit, great - NO! Both my MDF and router bit were dead on 1/2" but this left zero room for glue or even the tinyest amount of slop to help with fitting. I gently sanded the edges of all the internal ribs and this made fitting a lot easier.
However, when it came to adding the top things were not so simple. Even having sanded the rib edges trying to get the top to fit became a PITA. I had done everything else before lunch today and expected to simply glue and nail the top down in 30 mins. No such luck and it actually took me the rest of the day. Bottom line is that IMHO tight fitting dadoes in this application are not a good idea. Having a little "wiggle" by either using slightly undersized MDF or cutting oversized dadoes would have been best. I ended up having to shave a hairs width from each of the ribs to get it to fit.
Here is the completed Torsion box. The eagle eyed amongst you will notice a little mistake - yes that gap in the corner near the water bottle. This is a prime example of "measure twice - cut once, measure once and SCREW UP!" I had setup all my cuts for the sides and ribs using my x-cut sled and a stop block. My usualy routine is to first cut slightly overszie and then trim down to final length. I always make a squaring trim cut on the first end before cutting to final length and in this case I didnt bother to meaure how much room for error I had and ended up taking off too much with my first cut Leaving that side a 1/16" short
Its not too much of a problem as I intend to skin the edges of the torsion box with ply to match the rest of the cabinet.
Thats all for now, I should be doing the main cabinet next weekend and will add the 2nd installment to the BT Mobile Base Diary.
Keep up the detailed posts!
) which is pretty typical.
