Kid's Kitchen: Need "clicking" knob design
  • skipowder8s
    • Nov 2008
    • 6
    • Denver, Colorado
    • Sears 21929 w/Ryobi Router
    Hey gang,
    Anyone have a design for "clicking" knobs?
    I'm building a kitchen for my 3 1/2 yr old daughter and spinning wood disks just won't cut it...I need the knobs to click when spun.
    Was thinking of a small plastic piece mounted inside of the oven cabinet with some kind of barb...but my inexperience in wood working is limiting my thought process.
    ...and yes
    - the countertops and backsplash will be granite
    - the stove rings will glow red w/LEDs
    - there will be under cabinet task lighting
    thanks for any help/guidance.
    best regards,
    mark
    Best regards,
    Mark
    New to wood working.
    This is my first table saw (Sears 21829).
    Kid's Table and Chairs, Storage Box w/hidden drawer
  • sscherin
    • 772
    • Kennewick, WA, USA.
    I ran through a couple ideas then thought.. Why not use the knobs and pots from a real oven? Call an appliance repair shop and see if they have a set from one heading to the dump.
    If you want to get fancy you could wire them to those LED.
    option 2..
    Go to Ace HW and get a 1/2" ball bearing and a matching spring
    cut notches radially around the back of the knob with a round or v router bit
    Drill a 1/2 hole in the cabinet behind the knob deep enough to hold the spring and keep the ball protruding about 1/2 way out of the surface..
    Now with the knob bolted on the ball will ride the notches like a detent.
    Yet another simpler idea..
    Round disk on inside of the cabinet with dowels mounted in it plus a plastic flap for a clicker. Like a playing card in bicycle spokes..
    William's Law--
      • 22098
      you could use something like this:
      http://www.rockler.com/product.cfm?p...r=ball%20catch
      behind the knob mounted in the face of the console and then put some holes around the back of the knob.
      • skipowder8s
        • Nov 2008
        • 6
        • Denver, Colorado
        Thanks!
        Lchien and sscherin, Thanks for the ideas....I really appreciate it.
        I think that I'll be combining some of your suggestions and go w/a modified 'card & bicycle spoke' approach. As suggested, I'll put in an internal disk; but instead of dowels for cogs, I'll route 'cogs'/gaps into it and add a plastic flapper.
        3 heads are better than 1.
        Best regards,
        Mark
