Proper Blade For Cutting MDF / Plywood
  • brubakes
    • Jan 2009
    • 61
    • Medina, OH
    • Sears 315.228110
    What blade would you recommending when cutting MDF or Plywood. Any thickness. I always seem to splinter the ends.
    I am going to answer on the assumtion that you are cutting on a TS.
    A 60 or 80 tooth thin kerf blade will give you clean cuts. To avoid splintering or tearing of the ends of the cut, or the veneer, use a zero clearance throat plate for the bottom of the cut and run a strip of blue painters tape along the cut line on the ends and top.
    • brubakes
      • Jan 2009
      • 61
      • Medina, OH
      • Sears 315.228110
      Yes, I did mean on a table saw. Thank you!
        • 9568
        I have been using a Freud Diablo 40T general purpose blade for that, and I get no tearout. Just make sure you use a zero clearance throat plate and you should be fine... A dull or dirty blade will tear out as well...
          As the OPs have said a ZCTP will help. Depending on how big the pieces are you intend to cut, a panel sled will help with cuts across the grain as the the bottom (where tear out is usually worse) is inherently supported by the edge of the sled.
            MDF, whatever junk blade I have around, plywood, high tooth blade is the common thinking, I usually just use my wwII. A nice sharp blade does the trick. I also have a ZCTP though, and cross cutting I do with my sled, so it's also zero clearance.
            • Knottscott
              • 3815
              • Rochester, NY.
              • 2008 Shop Fox W1677
              The cleanest cutting grind for ply and melamine is a Hi-ATB combined with a fairly high tooth count. Infinity's 010-060 and 010-080, Freud's LU79R010 (TK) and LU80R010, Forrest's Duraline, or CMT's 255.080.10 are all excellent examples. Infinity's 10% Winter Sale puts the 010-060 at ~ $63.
              You can also reduce tearout by pre-scoring the cut line, and putting painter's tape on the cut prior to cutting. Using a ZCI helps a lot too.
                For MDF I generally won't use my good WWII. I usually end up putting my stock blade on for it. MDF may cut easily, but it will also dull a blade quicker than most woods. Sometimes I might use a better blade for MDF core melamine if it needs to be a nice finish cut.
                • brubakes
                  • Jan 2009
                  • 61
                  • Medina, OH
                  • Sears 315.228110
                  Thank you all for the information. I have never used anything but the OEM throat plate which as you know is not near zero clearance. To be honest I think my blade I've been using has seen its better days. Might be time to spring for a new one.
                  • Armini
                    • 120
                    • Ottawa, Ontario, Canada.
                    Try the ZCTP first - you will be shocked. Made a bigger difference than a resharpening.
                      Ditto Pappy on the painters tape and Knotscott on scoring with a razor blade knife first. By scoring with a razon knife and straight-edge you are essentionally cutting the veneer surface on the ply and the painters tape will avoid lift-out. It both sides will show... do it on both sides.
                      I use a 40 T on ply and a 24 T on MDF. MDF will cut well on about any blade but it dulls on quickly so Scotts idea of using a junk one it good. Also wear a dust mask as MDF dust is nasty.... nasty I tell you.
