Removing Brads/Staples
BT3 FAQ - https://www.sawdustzone.org/forum/di...sked-questions -
Perhaps I'm alone in this, but this thread both troubles and alarms me. Shop tasks routinely test our imaginations and ingenuity, but I don't make a habit of using my tools to do things for which they were never designed. I am especially careful to shy away from practices that common sense tells me might be unsafe -- which IMO is the situation here, given that a pneumatic nailer is essentially a firearm. Even if I did these things, however, I'd keep them to myself. I would never describe the procedure on a public Internet forum and suggest someone else try the same thing, under the guise of offering a "tip." But, again, maybe that's just me. Even so, I would suggest anyone thinking about trying this "tip" to think twice before you do it.
Loring, I have used your method to remove errant air-driven fasteners from both softwoods and hardwoods, as well as from plywood and MDF, all with good results.LarryComment
I have had my share of SOL.
Great Tip. I have used pliers, vise grips, wire cutters, hammers, and nail sets to try and get them out. So I appreciate the suggestion!Often in error - Never in doubt
MikeComment
I have tried most of the above mentioned methods on soft and hard wood. I now try to pull thru first with a six inch nipper with a one inch wide jaw that is rounded so that it rolls the brad or staple[after it has been nipped in half]out with very little, if any marring. When salvaging old finish lumber, it is usually bone dry and driving back the way they were driven in tends to split out the hole.Comment
When salvaging lumber such as trim, it is better to pull "hand driven" finish nails on through the wood or trim from the back to keep from "blowing out" the hole. Now if I could just get my guys to realize this I wouldn't have to buy as much wood putty.I have tried most of the above mentioned methods on soft and hard wood. I now try to pull thru first with a six inch nipper with a one inch wide jaw that is rounded so that it rolls the brad or staple[after it has been nipped in half]out with very little, if any marring. When salvaging old finish lumber, it is usually bone dry and driving back the way they were driven in tends to split out the hole.
Mike...I'm going to try your approach out first chance I get to see what kind of results it produces on pneumatic finish nails. Sounds to me like it might be a great tip. Do you ever have the blow out situation doing this on trim?Comment
Footer Ad
LCHIEN
