I'm planning a jewelry box much like this:
But what I want to do on the inside is have a heart on the lid like this: http://www.bt3central.com/showthread.php?t=27245 but the thing about that is the left (or right) side of the heart is gonna be the release to a secret compartment- when you squeeze that side up to the other side, its gonna pull two dowel rods out of the side that will let you pull the fake top out and open the compartment.
The thing is, I'm not sure how strong to make the springs that hold the dowel rods out normally. I was thinking that a total of 5 lbs to release the entire thing would be sufficient without making it impossible to open (I don't want the release to be obvious, but I don't want it accessible to superman only), and that with 1/4" of compression and about 1/2" of spring compression in the open position that I'd need a spring with at least 3/4" compression length, and since I'm using two I'd need 2.5 lbs each at max compression which is 3/4" to have a spring that compresses at about 3.33 lbs/inch, am I correct? Do the numbers I'm using make sense?
And of course, where can I buy these springs? The two places I found want to change me extra for not ordering in bulk and want like $4 a spring.
LCHIEN
