table saw for hollowing seat bottoms?
  • jrnewhall
    • Oct 2005
    • 57
    • Rochester, NY.
    • Ryobi 3100
    Fine WW had an article on using a router to do this. They made shaped side rails and attached the router to bars that rode on the rails. Sort of the same idea as using a router to mill a bench top except that instead of perfectly flat rails keeping the router flat, they used shaped rails to make the router go up and down. I may still have the article at home. If I find it I'll post the issue date. I think you use a shaped rail in the front and a higher, flatter rail in the back.
    ~JRN
      Originally posted by shoottx
      Now you owe me a new keyboard.
      Take one out of petty cash...
      • gsmittle
        • 2793
        • St. Louis, MO, USA.
        Originally posted by messmaker
        I read an article about doing it with a Skilsaw. It looked scary to me.
        I read that article, too. Personally, I'd rather keep all my fingers. That procedure looked VERY dangerous to me...
        g.
        Smit
        "Be excellent to each other."
        Bill & Ted
          • 9524
          Originally posted by herb fellows
          If you have an angle grinder handy, you can hog out a lot of wood with a sandpaper disc attached to it, to minimize the hand work somewhat. Probably best to do this outside, the sawdust goes flyin'!
          You do have to be careful though, it's real tough to put wood back if you take off too much:-)
          Another vote for the angle grinder, except I would suggest a flap wheel, a little less aggressive with the material removal than a regular wheel...
          • herb fellows
            • New York City
            Originally posted by WayneJ
            There is a disc made for the angle grinder called "Lancelot' Its like a disc with a chain saw wrapped around it I think its the one used by David Marks I know HF carries them.
            Wayne
            I have the lancelot, but I think he would be better off using the grinder-sandpaper method. The lancelot is a bit hard to control for this kind of project, IMHO. As mentioned here, 24 or even 36 grit would do it nicely.
            • herb fellows
              • New York City
              Now you owe me a new keyboard. Ice soaked all over it!
              Hey, if you're putting in for a keyboard, i'm putting in for a new pair of tighty whiteys. That was funny!
              • jrnewhall
                • Oct 2005
                • 57
                • Rochester, NY.
                • Ryobi 3100
                JP,
                Given all the choices offered here, I still like the idea or using a router to scoop out the chair seats. I couldn't find the Fine Woodworking issue I read it in but the article is on their web site. They have a free 14 day trial you can use to log in and get the article - Shaping Chair Seats with a Router.
                ~JRN
