Edge banding a circle?
    • 9568
    Not that I am planning on doing this anytime soon, but cutting out the disks for my Thien Cyclone got me to thinking....
    With so many tables being bade with plywood tops, how would we go about edge banding a round table top?
    My weird brain shifts drive LOML crazy too...
    Interesting question as I was thinking something similar this weekend as I was considering some options for a new project.
    The only options I could come up with were.
    1. use the thin iron on veneer
    2. use a laminating technique with thin strips
    3. use router and trammel jig similar to how one would form the original circle on pieces but keeping what would normally be the waste. Attach them to the circle and then trim to finished size again with the trammel.
    4. make the center of the circle polygonal e.g. 8 sided. attach solid edging to the sq edges and then make the circle with the trammel.
    All of the HW options above seem like a real PITA to do so you would really need to want to do this. Even though it may cost more in material I think I would be tempted to just make the top from solid wood, then no edging is required.
      Seven options come immediately to mind (there are probably more):
      1. Plastic laminate (assumes the plywood top is also PL covered)
      2. Wood veneer that matches the plywood (assumes the plywood top will be left exposed)
      3. Some other edging material, like the T-shaped vinyl or the metal that was used in the old days (can you say "ugly?")
      4. Bentwood laminations, using the round top itself as the form
      5. Segmented solid wood of the desired width, with each segment shaped to fit. This could be an arc on both edges (inner and outer), or flat on the inner side and an arc on the outside
      6. Use a quality plywood like Baltic birch and leave the edge plies exposed
      7. For a painted finish, apply wood filler to the edges and sand smooth
        For a wood edging, you got it covered pretty well. To do any wood curved moulding this thread is a short method.
          • 9568
          I did that once, and I LIKED the effect, even routed a nice double ogee in the edge on a table I built in my HS wood shop. It looked sort of like thin butcher block. My shop teacher HATED it simply saying that the edges of plywood should NEVER be seen in furniture...
          To this day I disagree with him. I liked the look. And yes it was a gap free hardwood ply. I think it was red oak though, not BB...
            Beauty is in the eye of the beholder
