[quote=91FE;372459]Having never cut a mortise, I figured I'd follow their suggestion and use my drill press. Maybe I should reconsider and figure out how to do it with my router???
//have decided to go with this one: http://plansnow.com/dn1135.html )/quote]Oh, you're going with that plan? I take it back, you'll never be able to do that in a million years!
Syche! That's a great design and you should have a lot of fun doing the project.
A plunge router is a great way to go for mortises, particularly compared to drill and chisels, which require a lot of patience.
Using a router also leads to the notion of mortise and loose tenon. In that technique you make mortises on both mating pieces and apply loose tenon into both mortises. This way the rounded ends of the mortises can be matched to roundover sides on the loose tenon, making the whole assembly very straightforward to make.
