Outfeed Table Idea
    kinda neat, I have been thinking about incorporating both the lowering wheel design with a heavy top bench/mobile bt base, to try and get the best of all things in my small space.
      I was thinking an overarm guard for my BT would be cool. Thanks for the idea on making one.
      • os1kne
        • 901
        • Atlanta, GA
        Very slick idea! May not be the best application for th BT3x00, but I can see the value for many saws.
        • Wood_workur
          • 1914
          • Ohio
          • Ryobi bt3100-1
          has no one thought of the idea of moving the wheels around abit so when its raised it will clear the blade and the fence?
          Alex
          • dlminehart
            • 1829
            • San Jose, CA, USA.
            Alex, I think the problem in having the wheels lower is one of leverage. Note that, with the wheels only one wheel-height lower than the table legs, the lever arm is already about half the width of the table. To comfortably jack a table up when the wheels are twice as far below the table legs would probably require levers as wide as the table. Not impossible, but getting more awkward once they overlap.
            I think there may be other ways of lengthening the legs, but they might be leg-by-leg operations rather than 2 legs at a time. Worth thinking about, though, as it really is a good solution for a lot of us short on space.
            - David
