Turning Two Sheds Into One
    When we bought our present home there was an 8' x 10' metal shed which was falling apart. So I bought two identical 10' x 12' metal shed kits and set them up side by side with a 2' walkway in between.
    They didn't come through Hurricane Wilma very well. As in the picture below, the right shed must have been subject to a tornado during the hurricane, as the entire shell was taken away and everything inside stayed in place...weird.
    Instead of replacing the shed with a metal one I built from scratch a 10' x 12' on the same foundation. In the picture below the two sheds can be seen.
    Here's what I want to do. I don't like the appearance of two different sheds. I want to take down both and put up a single structure, covering both foundations and the 2' space in between. The overall size would be 22' wide by 12' deep. I'm thinking that If I build this, the size would require a more involved truss structure than I used on the single shed. The shape being close to square would provide more storage and better access.
    My dilemma is to figure out whether I should build the structure or just buy one like one of those steel buildings. I don't know if there is a way to limit roof height, but I don't want to go much higher than 8', less if possible. A flat deck roof doesn't sound too appealing, so these are some of my parameters. I'm open for suggestion.
    • 9562
    If you are doing this for storage, there are PLENTY of low profile shed plans available online. Depending on your space in your current shop, if you are wanting to use this as shop space, I wouldn't limit to the 8 foot range if at all possible...
    I like the size you are working with for sure. A Gambrel Roof mini barn would be great for a shop unless it would clash with your current architecture / neighborhood look and feel...
    Whatever you chose to do, there is a good selection of shed plans at http://www.freeww.com/storagebuildings.html that you can strip ideas from...
      Thanks for the reply. I don't need this for a shop, storage only. If I build it, I don't need plans, maybe just some roof ideas because of the height. I'm also considering the idea of one of those steel buildings if anyone has any feed back on them.
        At 22x12, you are basically looking at something on the order of a single-car garage plan, turned sideways. You can gain extra storage space above by doing a truss layout for a gambrel-style roof (barn roof). Just remember to double up on your wall studs if this space is to carry any significant weight.
        • wardprobst
          • 681
          • Wichita Falls, TX, USA.
          • Craftsman 22811
          Built a metal building and it's held up to 100mph winds and 10" caliper limbs falling on it without a leak or whimper. It's about the lowest pitch roof you can get that will do that.
          DP
          www.wardprobst.com
          • Tom Slick
            • 2913
            • Paso Robles, Calif, USA.
            • sears BT3 clone
            It might not be applicable to you but around here you have to get a permit for any structure over 120 sq-ft. That's why prebuilt/preengineered sheds are often 10x12 max.
              They do issue permits here for what they call "outbuildings". Both foundations are already within the guidelines for easement/property line requirements.
                A 3/12 pitch would only give you an 18" total rise on a 12' wide roof. A wall height of 7' would get you down to a total height of 8'6". Metal roof, 16" on center framing and hardipanel on the walls and that sucker aint going nowhere!
                • OpaDC
                  • Feb 2008
                  • 393
                  • Pensacola, FL
                  Since your in north Cuba don't forget to check with wind insurance and code requirements. I believe metal sheds of certain size (maybe all) are required to be strapped down like trailers are.
                  _____________
                  Opa
                  second star to the right and straight on til morning
