I personally feel Jon, that the base is "more" important than the top as long as you flatten the top. I have built around 20 + benchs (I lost actual count as I generally build one every summer during the humid monts since the mid 80's) and if the base is solidly built, you can add another top in a few days as I just did.
And you don't have to do it now as saw-horses will suffice till you get around to it if necessary. It's just a work-bench made for work. But.. when you do get around to it.. if you don't use metal attachments... through M&T's.. bridle joints.. etc. should be used IMO. A sturdy base is the foundation for the top and it will allow a top to rack under heavy hand-planing regardless if you have the strongest top in the universe.
I test my benches by rounding up 4 teen boys and offering them $10 each to rack it. They push.. pull.. and use their teen testerone as teens do and if it holds (and that design will with just joints in place and not even glued at that point) the base if ready for the sacrificial top.
Just my theory as I feel too many get caught up in makind show-pieces that take much too much time away from building show-pieces. And I also feel many they think it must be built with rock solid timber as the traditional maple (US) and beech (Europe). But that is somewhat over-hyped as much as giving a WW a machinist calipher and turning him loose on his TS or whatever.
I answered a post the other day elsewhere where the guy had his shorts in a wad because his ripped stock was .004 off. He got around 20 answers on how to fix that before I chimed in to get to work. I challenged everyone to look at .004-.008-.015 and even .020 on a cheap feeler guage to see that you can't force a knat's butt between any of them. You get more tolerance than that from tension being released from the wood when severing it.. run-out of the blade and compression when clamping on glue-up.
High tech is great... but it is often carried well beyond where it should be. You won't find one professional that will labor on a bench for 6 month or a year or worry about .020 tolerance as they don't have that kind of time for foolishness. They would laugh if you mentioned either as they can distinquish what is important and what is not.
Good luck with your bench as already mentioned...
