Drilling into Concrete in small spaces
  • rnelson0
    • Feb 2008
    • 424
    • Midlothian, VA (Richmond)
    • Firestorm FS2500TS
    I have a nice hammer drill that I use for anchoring objects to concrete, works great. However, my wife has something she wants me to hang at work and the space is only about 8" wide where the drill would have to go, and that's about 5" too narrow. Does anyone have a good idea for drilling into the concrete in such a small space? If it wasn't concrete, a right-angle drill would be perfect, but I'm not aware of any that have a hammer functionality at a decent pricepoint.
  • MikeMcCoy
    • Nov 2004
    • 790
    • Moncks Corner, SC, USA.
    • Delta Contractor Saw
    Suggest she find a different spot.
    Even a right angle drill might be pushng your width.
      A non-hammer drill willwork, it just takes longer.
      How heavy is what you have to hang? Construction adhesive can be your friend - glue a wood plate to the concrete and hang whatever you need to from that.
        • 22029
        just don't forget to predrill the wood plate before gluing!
        • 91FE
          • 303
          • Philadelphia (actually Souderton), PA.
          You can do it with a masonry bit in a regular drill. Power actuated fasteners are an option too... but they're not very precise.
          I like Wagoneers too. Hey...they've got wood
            How about one of the hanging hooks by 3M with the double sided tape on the back?
              Youm could chuck an angle drill attachment to your hammer drill, and it may transfer some vibes to the bit.
              • rnelson0
                • Feb 2008
                • 424
                Probably going to have to glue it up. My wife measured it today and it's less than 7" wide. Not even room to swing a hammer.
                • Seedy
                  • Feb 2007
                  • 31
                  Could you possibly fasten a board to the concrete with long tapcon screws going in at a 45 degree or more angle? Or would that not support the weight?-Craig
                  • rnelson0
                    • Feb 2008
                    • 424
                    I'll find out today when we go in to give it a shot. I'll bring the tapcons just in case, but I doubt it - the heads would stick out too far for flush mounting anyway, but the space is narrow and deep, don't think I'd be able to get the back screw in at any more of an angle than 30 degrees. In the meantime, I'm off to HD to find some appropriate glue and some short scraps of wood.
                    I forgot to ask. What do you mean by this? I use a masonry bit with my hammer drill and if I forget to flip the hammer on, that bit isn't going ANYWHERE. Certainly not before the drill kills the battery.
                    • 91FE
                      • 303
                      You can do it with a regular drill and a masonry bit. Sure... it won't go as fast as a hammer drill, but it will go. I don't have a hammer drill, but have drilled in concrete walls and cement stucco several times with my regular drill.
                      • rnelson0
                        • Feb 2008
                        • 424
                        For shits and grins, I tried this today. After 10 seconds all it did was scrape the paint off the cinder block. Flipped it to hammer, 10 seconds later the 2" hole was done. Yeesh, for the $20 extra it cost over the non-hammer drill version it's worth it to me!
                        In any case, for the areas where I couldn't get the drill in there, I bought some Construction Adhesive caulk and used that. Only one of the four pieces were dry when we left, but that one wasn't going anywhere when I pushed on it. The pipette holder going on the wall will wait about 5 pounds. Should be safe
                        • billwmeyer
                          • 1868
                          • Weir, Ks, USA.
                          Drill bit extension
                          How about using one of these?
                          http://www.lowes.com/lowes/lkn?actio...002&lpage=none
                          It chucks into your drill and the bit attaches with a couple of set screws. I have used 36" of extensions before.
