Source for Wood Screws and Shock Cord
  • pierhogunn
    • 1567
    • Harrisburg, NC, USA.
    I need to line up a source for some brass wood screws and some 1/8"dia shock cord.
    I have a project to build 20 flag poles and I would like to save some money and buy in bulk
    I will need about 500 #8 1/2" flat head brass wood screws, and about 50' of shock cording
    Monty Python's Flying Circus
    Dan in Harrisburg, NC
    • 22060
    for the screws I'd look in the yellow pages under fasteners, nuts and bolts. or in the internet, google for fasteners
    Shock cord - you mean like bungee cord? Not sure I understand the use of bungee cord in flagpoles, if a raise/lower kind of pole elastic cords will billow out uncontrollably in the wind, bad... if a fixed-flag pole then???
    • pierhogunn
      • 1567
      the 1/8" cord is for the pole joints.
      Also, anyone have any advise for burnishing the indside edge of a cleanly cut piece of aluminum tubing?
      also anyone know of a good supplier for anodized .875OD aluminum tubing in Charlotte, I'm googling, just wanting to know if anyone knows of some other local sources
      • 182much
        • Jan 2008
        • 92
        • Norco, CA
        shock cord
        I just found a bunch of shock cord on ebay express.
        Different sizes, colors, and lenths some are 500 ft spools
        Here's the link
        http://search.express.ebay.com/items...53D1Q26fgtpQ3d
          McFeely's has the screws (slotted head only, alas) for $4.14 per hundred, drops to $2.69 if you buy 10 boxes or more. Plus shipping, of course. (Have you priced the screws at your local big box stores? Qty: 500 isn't really what I'd call "bulk;" for only fives boxes, you might do about as well buying locally.)
          McMaster-Carr shows 1/8" shock cord for nine cents per foot. Given your location, you'd get quick service (probably overnight) and cheap shipping from their Atlanta location. They're high on the screws, though ... about $8 per hundred.
          • pierhogunn
            • 1567
            McMaster-Carr, really, never thought I would order anything from their, well time to go diving.
            Dan
            • Mr__Bill
              • 2096
              • Tacoma, WA
              Try something like this
              or these from Rockler
              • pierhogunn
                • 1567
                that looks like just the ticket, I have a little sanding drum form my dremmel...
                • iceman61
                  • Oct 2007
                  • 699
                  • West TN
                  • Bosch 4100-09
                  If by burnishing, you mean deburring the inside or outside edge that rolls over when you cut it, there is a tool we used to use in the shop that was alot faster that getting out another bit &/or power tool. After we used them, they seemed indispensable & all the fabricators kept one in their pocket. Just one or two twists of the tool on the inside &/or outside edge & it shaves the rolled over edge off to chamfer the edge of the steel. It also works on straight edges. The actual cutter is carbide & stays sharp for a very long time. We used them on steel so I know they will cut aluminum like butter. I think we got them from McMaster-Carr or you can google "deburring tool".
                  • Tom Slick
                    • 2913
                    • Paso Robles, Calif, USA.
                    • sears BT3 clone
                    That tool is called a "rout a burr" they work great for deburring
                    • ksum
                      • 69
                      Try a good outdoors store that caters to camping, rock climbing, and/or kayaking. They normally have shock cord to replace what is used on the toys they sell. You can often get it by the foot.
                      Karl
                        If you have a Fastenal store nearby, check with them on the screws.
