Aromatic Cedar - Looking for inspiration
    I just picked up a heck of a deal (found on CL) for Aromatic Cedar. I just picked up Approx 75 Bd/ft, 20 4/4 boards, mostly 8ft long for $60. I couldnt resist the deal so now I just need to figure out what to do with it
    Two projects that were on my list are a desk and a patio table. Not sure how this cedar would hold up to outdoor use. Any thoughts?
    • 22074
    that sounds lieka pretty good deal. Cedar is rot and insect resistant - it will last many times longer outdoors than other woods.
    Some poeple leave it natural and others like to put a varnish on it, the varnish will probably have to be renewed every year, I think.
    You'll love the way it smells when you are cutting it.
      I was thinking of using an oil based finish rather than a varnish or poly.
      You are right about the smell. I had to trim and end off one of the boards and it certainly makes a nice change from that plain dry sawdust smell..
        What a good find. If you use it outdoors, I wouldn't use any varnish of any kind. I would leave it natural or use just a pure oil on it like pure tung oil. When needed, lightly scuff sand and re-oil.
        If used indoors, like in a closet, don't seal with anything. When the aroma starts to dwindle, rub with bronze wool.
        • mschrank
          • Oct 2004
          • 1130
          • Hood River, OR, USA.
          As Loring said, it's great for outdoor use. Probably too soft for a desk, though, unless you eventually want the "distresssed" look.
            I wonder if I finished the desk with a hard wearing poly topcoat wether this will help?
              Wouldn't try the desk, regardless of finish, but agree with C-Man's suggestion of outdoor table, unfinished or with tung oil. Indoors, I'd slice 'em thin and line a closet, or maybe build a blanket chest (tung oil outside, unfinished inside). One caution: The smell is delightful, but the dust will screw up your lungs. Wear dust mask or respirator when sanding, and ventilate your shop to the outside.
              • steve-norrell
                • 1001
                • The Great Land - Alaska
                Double ditto on Uncle's comment. I gives me a serious hayfever-like reaction. A respirator is a must. See the attached file for more information.
                Regards, Steve
