I glued up a panel for a coffee table, 4 boards 1-1/4" thick to make a panel 20" x 40". The wood I used, soft maple, is from a local mill. Its been in my shop almost a year, so its been well over a year drying since it was first cut. So I built a router thicknessing jig to flatten it. The panel had a little cup to start out so I put the crown up in the thicknessing jig and took off just a smidge down the center, basically flattening the center 12 inches. then let it go for a day since I had to go to work. The next day I find the panel had reversed its cup, about 1/4". I flipped it over and planed the other side barely taking 1/8", samething, off to work. This time the corners curled up about 5/8". Dicouraged, I let it sit for a few days. I looked at it this morning and its laying pretty flat. Is this normal? Anyone else have this dilema?
router thicknessing jig and wood movement.
Sometimes, after cutting or planing wood, even if it's dry, you get what is called reaction movement. This is where built-up stresses internal to the wood are allowed to release when the wood is "vented". Some woods are more prone than others, and how the wood is stored (and what condition it was in when storage began) and grain characteristics of the piece are contributing factors. Sounds like you took off enough to let your board boogie down.Comment
