Garage floor epoxy. It's relatively inexpensive when you figure you get a gallon for about $60. I was surprised to also learn that it is water-soluble so cleanup is easy, and it has about a four hour working time. It's fairly thin compared to regular epoxy. It's easy to mix up a cupful in a disposable plastic cup and pour it on as an indestructible finish or use it for support on projects. Right now I'm using a batch to line the inside of a plant holder made from thin Wenge and Zebrawood. It's thin enough to worry me, but with a couple coats of this stuff it will be solid. And of course, this makes it waterproof.
The epoxy starts out as a white liquid and dries perfectly clear, not yellowish like many epoxies. So it's suitable as a finish for anything that needs to be waterproof and/or tough. It's easy to do a heavy layer and embed things in it. I'm going to do a card table with cards and chips in it.
