Can't find HDF - Speaker Build
  • avaserfi
    • Oct 2007
    • 42
    • Ames, IA
    • No room for one - yet. :(
    Hey guys, I just found this site and think it might be the perfect place for me . I do quiet a bit of various woodworking and have recently delved into the world of speaker designing using the Toole approach to design. Currently I am designing a modular 4-way speaker with near zero cabinet resonance, but am running into one big problem. I cannot find a local or online HDF supplier that has 3/4" sheets and was hoping someone could help me out there!
    I will be doing the build in the Dallas TX area and have been calling everywhere, but the best I can find is double refined MDF which has a density of about 55lbs per cubic foot. I have a friend who does this and he uses HDF with a density of 80-100lbs per cubic foot and I would really like to get a material of comparable density as I don't want to make a steel/MDF laminate.
    So if anyone knows a place I could get 3/4" HDF or a material with a similar density for a reasonable price I would be very greatful! I figure worst case scenario I will have to blow some extra money and get Corian, but would like to save some money and find the HDF.
    Thanks!
    -Andrew
    I have a cousin in Ft.Worth, and he suggests a place in Dallas called Wood World. I looked for their website, and am getting nothing but errors. Might be worth a phone call though.
      Uncle Cracker,
      Might this be the place?
      http://www.woodworldtx.com/
        Originally posted by crokett
        Uncle Cracker,
        Yep, that's it. For some reason, thier page comes up nothing but boxes and diamonds in Firefox, but I see it works fine in IE.
        Still don't know if they got the HDF in stock though...
        • avaserfi
          • Oct 2007
          • 42
          • Ames, IA
          I just called Wood World. Unfourtunatly they don't carry any HDF, infact the guy I talked to said he has no idea where to get it as three other people have called in the recent past .
          Anyone else have any ideas on what to use or where to get HDF?
          Thanks guys
          -Andrew
            • 22098
            HDF is high density Fiberboard, which is a term for Compressed wood fiber originally sold by Masonite.
            "Hardboard (Hard Density Fiberboard - HDF)
            HDF is a high quality panel manufactured from specially engineered fibers that are compressed under heat and pressure. These panels are produced by a "wet" or "dry" process.
            The "wet" process produces panels 1/8 or 1/4 inch thick that have one smooth side and a screen pattern on the backside, and are designated S1S. The "dry" manufacturing process produces a panel that is smooth on both sides, or S2S. Hardboard was first produced in 1924 by W. H. Mason, founder of Masonite Corp. The term Masonite is therefore often used to denote hardboard products, High Density Fiberboard (HDF) has a density that ranges between 50 and 80 pounds per cubic feet.
            Standard hardboard has excellent machining and finishing properties suitable for numerous interior uses such as paneling, partitions, furniture, toys, packaging, flush doors, garage doors etc.
            Tempered hardboard is impregnated with special oil that is polymerized by heat treatment. It is particularly suitable in applications where there is a need for extra water resistance, surface hardness, rigidity, bending and tensile strength. It is often used in construction siding."
            from http://www.keidel.com/design/select/...tl-eng.htm#HDF
            Here's a Wikipedia ref:
            http://en.wikipedia.org/wiki/Hardboard
            The pegboard you see sold in HD, etc is thin masonite.
            So I'd suggest checking Masonite sources but they appear to have morphed into a company selling doors.
            Wikipedia also says this:
            "Large-scale production of MDF began in the 1980s. Its name derives from the distinction in densities of fiberboard. MDF typically has a density of 600-800 kg/m³, in contrast to particle board (160-450 kg/m&#179 and to high-density fiberboard (500-1450 kg/m&#179. Similar manufacturing processes are used in making all types of fiberboard."
            so not all HDF is denser than MDF. So if you plan on the greatest density, then you must specify it when you buy!
            I think you should make your speakers out of granite or Marble or welded steel plates.
            • avaserfi
              • Oct 2007
              • 42
              • Ames, IA
              Whenever I call a store I always specify specific densities required
              Welded Aluminum would work well with proper bracing (although milled would be way better!), but I don't have the kind of money needed to do that.
              Since it seems as if appropriate HDF will not be found (I have called around Masonite suppliers too) does anyone know another material with comparable density (80-100lbs per cubic foot) or a good place to get well priced Corian as that will work too.
              Thanks!
              -Andrew
                • 22098
                Thanks!
                you might hang around and befriend (those guys like beer...) some kitchen cabinet/countertop makers... They use Corian by the yard and cutoff slabs that are too small to use for countertops might be big enough to use for speakers sides.
                • avaserfi
                  • Oct 2007
                  • 42
                  • Ames, IA
                  I have been working on that . I recently contacted a couple companies for price quotes. Problem with my design is the smallest piece is 4" wide, but 30" long or 14"x18" so extras won't work .
                  Thanks for the help. I will be sure to keep beer on hand just incase.
                  -Andrew
                    If you have beer, you don't need Corian... Problem solved...
                    • avaserfi
                      • Oct 2007
                      • 42
                      • Ames, IA
                      but...but...but...Music and good beer go so well together .
                      -Andrew
                      • mburdette
                        • 64
                        • Little Rock
                        I don't know if you're still monitoring this thread, but...
                        I design and build speakers.
                        I got a hold of HDF from a commerical shelving and cabinet installer. I actually got as much as I could haul, for free, twice, after posting a "wanted" ad on our local Freecycle. I see you've already contacted some countertop/cabinet guys. But you might try calling around to commercial/industrial shelving and cabinet companies. The pieces I got were all either close to 24" x 30", or around 11" x 8 feet (but were still 'scrap' for this company). I originally wanted the material for a 6 ft3 subwoofer cabinet containing an 18" professional sub driver, driven by 1000 watts. The cabinet was a tank. I've used the leftover (more than half of what I acquired) for various other projects around the house.
                        Also, I know some guys use a layer of concrete on the speaker cabinet panels to achieve the low/no resonance you're after.
                        • avaserfi
                          • Oct 2007
                          • 42
                          • Ames, IA
                          Great idea . I will check it out.
                          I am actually trying to make this cab of "reasonable" weight (less than 300lbs each). Otherwise I would be making a solid concrete one or using a 3/4" HDF 1/4" steel laminate with steel bracing rather than aluminum, but concessions need be made so it is.
                          I will check out your ideas. Thanks.
                          -Andrew
