And one forum member calls MICA!
It has been my experience that even if this is true, which I doubt highly BTW, that there is a world of difference in the wear charcteristics between the two. I once used melamine, banded with solid red oak as my wide table extension/ router station with my saw. In less than 2 years time I had worn through the color at the corners. I've had my present sawstation that I used wilsonart laminate on and 3 years later and many more projects when comparred to the other one I see no wearing. It is possible that flatness has played a factor and it is also possible that the difference in texture has played a part. The old one was gloss and my new one is matte. It could also be that there is more than one grade of melamine and I used a low grade. It could also be that melamine has a thinner color layer than sheet laminates. I do not know.
You've probably heard of, and seen, something called melamine ... this is simply that same visible "skin" layer applied directly to a structural substrate such as particleboard or MDF, with the phenolic backing omitted.
Black wallnut
