I'm doing a stair renovation project. and I am putting in a new handrail with iron balusters. The balusters are 1/2" square and I will need to drill holes at a 45 angle (or so - at the measured angle of the stairs) into the shoe and into the underside of the handrail it self.
I have made a jig for my drill press, to test my drilling on a scrap piece of wood, and will make a second that is 'better' quality that will have drill bushings and possibly change it to be for a hand drill so I can do the handrail and the shoe which is part of the existing stair case - so it won't exactly fit the drill press
I have a couple of options I think.
1) drill a slight oversize hole (across the corners) with a brad point - but the baluster could now turn
2) Drill 1/2" and chisel out the square
I think option 1 is the best option because of the margin of error is better and figure out some way of keeping the baluster from turning.
Any ideas or suggestions before I start. tips on drilling holes on the 45?
TIA
Stephen
TIA
Stephen
LCHIEN
