Hi all
It sounds like I'll be building a sewing room full of cabinets this winter, proabably in birch or similar light wood. Since I don't have tools for either, I was hoping for some advice on biscuit vs pocket screw construction.
Aside from clamping time, are biscuits easier align because of the built-in slop?
Do biscuits work in melamine? Most imprortant, does one system have a shallower learning curve?
I'm leaning toward a biscuit joiner because I think it will be more versatile in the shop but I'm all for the easiest method.
Thanks,
Eddy
Thanks,
Eddy
LCHIEN
I've used both methods and both have their strong points but for ease of use, strength and speed I use pocket screws almost all the time. I mostly only use biscuts in glue up for tops and if the pockets would detract from the appearancce. I made my wife a cutting table with cabinets underneath using pocket screws and the pocket screws don't show at all unless you get down on hands and knees and search for them. The biggest plus I find for pocket screws is you can do the glue up without clamps and then move the project around just as soon as assembly is finished instead of waiting for the glue to dry.
