How do I prevent rounding edges during sanding?
  • bmuir
    • Jul 2006
    • 63
    • Rochester Hills, MI
    I plan on building some simple, gravity wine bottle holders for Christmas gifts and I want to sand the surfaces to a very smooth finish. What is the best way to keep the edges at a sharp 90-degree angle during the sanding process?
    As always, thanks for the help.
    So little time, so much wood!
    Sandwich the piece you're sanding between two other similarly sized pieces.
    • ragswl4
      • 1559
      • Winchester, Ca
      • C-Man 22114
      Glue the sandpaper to a flat surface. Use a temporary fence to keep the wood at 90 degrees to the sandpaper and move the wood over the sandpaper. The fence could just be a straight board clamped the the same board the sandpaper is glued to.
      RAGS
      Raggy and Me in San Felipe
      sigpic
        You might also consider using a good, sharp hand plane instead of sanding, although it may take a little practice if you have not done it before.
          • 22063
          stationary belt sander.
          The follow with a good ROS disk sander with a fine disk and a fairly firm disk backing.
          If you're doing it by hand then use a fairly rigid sanding block, home-made of store bought.
