How do you cut an aluminum picture frame molding
  • bmuir
    • Jul 2006
    • 63
    • Rochester Hills, MI
    What's the best tool/blade/technique for cutting an aluminum picture frame molding to size. I have a 12" chop saw, table saw, hack saw?.
    Thanks for the help.
    So little time, so much wood!
    • 22033
    The BEST way is to equip your miter saw with a non-ferrous blade specially made for cutting brass, aluminum, or other soft metal/non-steel
    like this: http://www.amazon.com/Freud-TK706-10.../dp/B00006407O, TCG, negative hook angle.
    Then cut it on your 10-inch miter saw.
    I see you have a 12-inch saw, well, I imagine they have bigger blades.
    The compromise is to use your normal woodworking blade if you are not doing too many. Aluminum might be hard on a very beveled tip Hi-ATB blade like the ones for cutting laminates. but shouldn't be too hard for a couple of cuts with a normal all purpose WW blade. You can even use a table saw if you have a good miter fence and good dust collection to keep metal particles out of the inner saw workings.
      Too bad you don't have a band saw...
      If you're not making a lot of cuts, you could get good results using a hack saw and a miter box.
