Miter/Bevel angle
  • ufg8r85
    • Aug 2006
    • 49
    • Stuart Florida
    • bt3
    Miter/Bevel angle
    I wish to install a box fan in the corner of my garage near the ceiling. I'm thinking of putting a 2x4 or so across the corner, but I also want it angled down at 45 degrees. I'll then mount the fan to this, along with a piece from the ceiling to keep the fan in place.
    What miter/bevel angle should I make these cuts? 45 and 45 didn't work,is there a formula?...
    As always, thanks in advance,
    Steve
    Steve
    You can just make a compound cut and then you don't have to measure.
    Set the saw to make a 45 degree miter cut, then also tilt the saw (bevel) angle 45 degrees. and make the cut.
    You can do this with either table saw or a compound miter saw.
