Where can I find (or can I make) a fireman's pole?
  • markmt
    • 69
    • kathleen, georgia, USA.
    sir, i would go to a fence installer, they can bend any size stock you would need. i had a flagpole 30' high made from galvanized stock.
    good luck
    mark taylor
      Hi Alex,
      I'm making something along those lines myself for the grandkids. What you're doing sounds a little more elaborate than what I'm working on. I found plans in a library book, and it does show what they call a fire pole. It is simply made from 1" diameter galvanized pipe, a galv. floor flange (to attach the top of the pole to the structure), a 16" nipple, and a 90 degree elbow. The bottom is set in a footing of concrete. Good luck.
