Picture Frame Construction
  • davehenry
    • 46
    • Slidell, LA, USA.
    I need some our your expertise. Our daughter is getting married and I am going to make a picture frame to hold her wedding announcement. But instead of the traditional open back frame I want to cut a grove in the pieces. I can glue pieces 1, 2 and 3 and then slip in the glass/ announcement /wood backing assembly into the groove. Here comes the hard part. If I glue the 4th piece in, and the glass ever breaks, there is no way to replace it. I thought of magnets holding the last piece in but there has to be a better way.
    Any of you got a suggestion?
    "I can't be unhinged -- I already installed them!"
  • Tequila
    • 684
    • King of Prussia, PA, USA.
    Pocket screws. You can join it together from the back, and if the glass ever breaks, you can take it apart.
    -Joe
    • davehenry
      • 46
      • Slidell, LA, USA.
      In my haste I neglected to say that there will be 2 frames held together with hinges. It will be meant to set on a table. Would rather that no screws be showing.
      • Tom Miller
        • 2507
        • Twin Cities, MN
        Originally posted by davehenry
        ...It will be meant to set on a table. Would rather that no screws be showing.
        In that case, maybe make the bottom removable, and put countersunk screws through the bottom into the sides?
        Regards,
          • 22085
          small screws. Make the fourth side split front and back, split at the groove. Would only take a couple of screws to hold the back to the front, it would keep the glass in.
          • Garasaki
            • Sep 2006
            • 550
            What about dowels?
            HOnestly thought, is the likelyhood of the glass breaking, but the frame staying intact, that great???
            -John
            -Henry Blake
            • scorrpio
              • 1566
              • Wayne, NJ, USA.
              How will the hinges attach? The screws holding hinges can also hold the glass/etc retaining piece in place.
              • Bruce Cohen
                • 2698
                • Nanuet, NY, USA.
                If you cheat and use Plexiglass, it won't ever break.
                Bruce
                Samuel Colt did"
